2 door dead electric windows
SPADGE
Post Sat Feb 17, 2007 8:26 pm
Hi Brian :D
This iS i have here had a few gremlins in the electrical department which i am gradualy sorting. All except the windows :?
Basicly neither work at all with or without the doors open or ignition on/off.
Both switches are lit-up so power is getting there and both motors are fine as i checked them today. I have had both plug connectors appart from the door shuts and cleand them as best i can and still nothing :x
Any ideas please?
Cheers Spadge...
Post Sat Feb 17, 2007 8:32 pm
When you try to work one window, does the other switch stay lit? It takes a lot more power to work the motors than it does the bulbs, so a resistive connection somewhere could cause this.
SPADGE
Post Sat Feb 17, 2007 8:39 pm
Brianmoooore wrote:When you try to work one window, does the other switch stay lit? It takes a lot more power to work the motors than it does the bulbs, so a resistive connection somewhere could cause this.
Just went out and checked Brian
Pressing the buttons has no effect at all on the lights on the buttons not even a flicker so it would seem no power is being called for to the motors :?
Post Sat Feb 17, 2007 8:45 pm
Safety switch broken (stuck off) or blown fuse?
SPADGE
Post Sat Feb 17, 2007 8:50 pm
320iSE wrote:Safety switch broken (stuck off) or blown fuse?
They were the first things i checked mate!
Have also checked both switches and both motors
Cheers Spadge..
Post Sat Feb 17, 2007 8:59 pm
There's not much else left. In fact there's nothing left that is common to both windows. Whatever it is, it must be two faults, one for each side.
Power and earth must be present at the switches, or the lights wouldn't work. You say the motors work, so the only things left are the pins in the door pillar sockets (don't usually give trouble), and the switches (which frequently do), but if neither side work, it must be both of them.
SPADGE
Post Sat Feb 17, 2007 9:11 pm
Brianmoooore wrote:There's not much else left. In fact there's nothing left that is common to both windows. Whatever it is, it must be two faults, one for each side.
Thats the conclusion i reached Brian but was hoping i was wrong.
The passenger side motor was already in bits but still attached to the door when i went to test it so Mr DIY had already had his fingers in that one :? I changed the whole reg/motor with one i had here and tested it with a direct feed from a spare battery. Both work in that way no problem.
I'll have another go at the door shut gizmo's tomorrow but knowing what colour wires or what pin numbers are for the windows would be a great help if you know them?
Cheers Spadge...
eko
Old timer
Post Sat Feb 17, 2007 9:14 pm
Have you tried bridging the 2 wires going to the cut off switch?
SPADGE
Post Sat Feb 17, 2007 9:16 pm
eko wrote:Have you tried bridging the 2 wires going to the cut off switch?
Yes mate and another known good switch from another car.
I even spent a while removing an entire non-working alarm system that was bridged into the e/windows (for full closure) but this made no difference either :(
fugazi33
Post Sat Feb 17, 2007 9:19 pm
Was at Spadge's earlier, it certainly is a headscratcher :mad: everything checks out as it should but there just isn't anything happening when you press either of the switches, only conclusion we could come to is somebody has messed with the wiring somewhere :?
Post Sat Feb 17, 2007 9:47 pm
Wires to the LH door are black and purple. To the RH door they are black/blue or black/grey and purple/blue or purple/green.
I've got a house full of guests here at the moment, and am getting evil looks from the missus.
Post Sat Feb 17, 2007 9:50 pm
How about changing the switches for know good ones?
SPADGE
Post Sat Feb 17, 2007 10:01 pm
320iSE wrote:How about changing the switches for know good ones?
As per my last reply to you mate i have done that already!
SPADGE
Post Sat Feb 17, 2007 10:02 pm
Brianmoooore wrote:Wires to the LH door are black and purple. To the RH door they are black/blue or black/grey and purple/blue or purple/green.
Ok thanks for your help and tell the missus to be more considerate to my needs in future please :cry:
SPADGE
Post Mon Feb 19, 2007 12:05 pm
All sorted 8)
It turned-out to be the block connectors in the door shuts after all!
Both were knackered beyond repair and have been binned and the wiring hard wired so the problem will never arise again :D
