how to change fuel filter?
snoops
- Major Helmet
what tool do i need to undo the clamps on either side of the fuel filter? i tried allen keys and screwdrivers but nothing works?
5mm or 5.5mm 1/4" drive socket. Start the engine and pull fuse 11 to stop it to depressurise the fuel system.
There will still be a fair bit of spillage.
snoops
- Major Helmet
do i leave the engine on when changing the filter then?
also how much spillage will there be?
Pulling fuse 11 kills the fuel pump, so the engine will stall after a few seconds. Turn off the ignition and proceed.
If you don't depressureize the fuel system like this, you will be faced with petrol at 45 PSI pressure when you remove the first hose.
Chris-W
Andy335Touring
If you can, replace the rubber fuel lines either side of the filter because assuming they are original they will be a bit tired, i think it was about £15 for both when i did mine.
Second that! Mine developed pin-hole leaks, both sides of the fuel filter and hose going into the fuel rail
BMW fuel hose is a bit pricy though, and they're specially formed at the fuel filter due to the tight bends.
