opend car on drivers side!
doing so work on the car today around the filler cap, tried to pull it open, it was locked, so went to open the boot was locked, boot unlocked with the key fine
then when to check the passenger door, locked the key has never worked in this door anyway, so went inside and the little pin wont even pull up,
tried the key in the drivers door, it will look but not unlock, they key goes round but it wont unlock, (lucky i had the window open at the time!
bit of help needed then!
oh and i can lock the drivers door from the boot aswell
