old 325 engine into a newer 320
mrLEE30
Post Sat Feb 17, 2007 12:44 pm
if i have an older (1986/85) high compression 325 engine and manual box and i want to put it in my 1992 320 cab (auto) will the engine managment system need to be changed too? what about the loom??
cheers
mrlee
dazleeds
old skool raver
old skool raver
Post Sat Feb 17, 2007 12:51 pm
you can either swap over the older stuff
or use the later motronic and put all the sensors onto the new engine
not sure if theres anything else to swap
www.oldskoolfantasy.co.uk
Post Sat Feb 17, 2007 1:54 pm
If the old engine has the flywheel mounted sensors, then I would retain the 320 management. ECU, or at least its chip, will need to be changed.
mrLEE30
Post Sun Feb 18, 2007 5:19 am
could you please let em know what there is apart from flywheel sensor, o2 sensor, blue temp sensor, air mass sensor
and i presume if i swap the ECU's around i can keep my 320 loom (assuming it is the flywheel mounted sensor)
and finally..... if its not the flywheel mounted sensor what does that mean??
i only ask as these 2.5 engines are relatively cheap to buy a newer type so is it worth the hassle to swap the managament system/ECU or just go for a newer 325 engine?
ta lads n lasses i have come to the conclusion that a 320 slush box is not giving me the driving pleasure i am sure i will get from a 25 manual
mrlee
mrLEE30
Post Sun Feb 18, 2007 5:22 am
and just to make sure you understand i have a complete and running (i think!!) older 325 which i will use so parts are no the issue
plans are to change clutch and gubbins, and perhaps freshen up the engine/decoke/valves/haed gasket etc i have a few months andf a garage to do it....but is it worth the hassle or should i just buyt a newer engine!!
mrlee
Post Sun Feb 18, 2007 10:35 am
The age of the engine is irrelevant; it's the condition that matters.
Early engine has a higher compression ratio, so should give marginally better results.
When I said "old" engine in my post above, I meant the 325 engine not the 320. If both engines have the toothed pulley and crank position sensor at the front, then the 325 AFM and ECU are the only differences. Looms will be identical, unless the auto is the switched type, when the TPS and its connector will be different.
The auto TPS will work OK on a manual - it just has extra contacts for the switched auto ECU.
New valve guides and the valve seats tidied up, and the 325 will probably be as good as new.
Don't forget to change the sump gasket while the engine's out.
