I know that an M42 engine is from a 318iS and has 16 valves, but was there too versions?
How much would it cost to change a new profile gasket?
Also is it correct in saying that the early ones doesn't have a lamba sensor :S wouldn't that make idle a little erratic!
M42 Engine
Cava
The 318is only had one version of the M42 engine - the early e36 318is also had a similar version (though not identical) but these can used as a donor engine if need be. The only ones you will find with a lambda sensor are those that had the optional cat fitted but these were very rare on the e30 318is's.
Hope this helps!
Hope this helps!
Chris-W
