oil pressure switch?
snoops
Major Helmet
Post Fri Feb 16, 2007 9:18 pm
i discovered that i had an oil leak coming from the oil pressure switch,
how much are these and how much does it cost to repair one of these?
Post Fri Feb 16, 2007 9:21 pm
Very common, costs peanuts, and just unscrews/new one screws in. Five minute job.
sam325is
Post Fri Feb 16, 2007 9:24 pm
sorry to hijack thread.when this happens does your engine oil light come on on the overhead display computer? mine has come on yet my oil is at the right level and the sensor is connected
Post Fri Feb 16, 2007 9:28 pm
sam325is wrote:sorry to hijack thread.when this happens does your engine oil light come on on the overhead display computer? mine has come on yet my oil is at the right level and the sensor is connected
Nothing whatsoever to do with the oil pressure switch.
Level sensors can fail or get gunged up and stick. Take the level sensor out and immerse it in petrol for a couple of days, lifting it out and letting it drain several times.
snoops
Major Helmet
no it doesnt only comes on when the oil is below the bottom line on the dipstick.
Brianmoooore wrote:Very common, costs peanuts, and just unscrews/new one screws in. Five minute job.
i was quoted £45 labour for this!!
sam325is
Post Fri Feb 16, 2007 9:30 pm
ok, thanks :thumb:
Post Fri Feb 16, 2007 9:38 pm
snoops wrote:i was quoted £45 labour for this!!
Get your spanners out, then!
oze30
Post Fri Feb 16, 2007 10:10 pm
Mine come on and off. I shorted out the plug, and it still lights even when turned off/on again. Worse part is, its intermittent. Any ideas?
Post Fri Feb 16, 2007 10:28 pm
There are two oil level sensors in the same housing (except for an early stuff). One switches the light on when it is open circuit, the other when it's short circuit, so pulling the plug off and shorting it won't necessarily put the light out.
snoops
Major Helmet
Post Sat Feb 17, 2007 7:07 pm
when changing the oil pressure switch does the oil have to be drained first?
Post Sat Feb 17, 2007 7:28 pm
No
Demlotcrew
Post Sat Feb 17, 2007 7:50 pm
The switch is about £6 and you need a 22mm spanner or socket.
Two min job if that.
Andrew
oze30
Post Sat Feb 17, 2007 9:32 pm
Is this the same for an m30?
