Does anyone know what the difference is between the M3 caliper carrier and the standard E30 item, i know the M3 uses 25mm discs but i'm wondering about the mounting and how far it is from the centre of the hub.
Is it further out due to the caliper carrier or is it the mounting holes are further out on the hub ?
M3 Calipers
Martinaston
There is NO nucleus.
old_skool
Martin,
PM Buster, he has a set of M3 calipers sat around and has done loads of measuring and bracketry with other calipers for his E30 so is sure to know the answer - I'm sure he will be able to offer any info on them,
HTH
HTH
Martinaston
Cheers i'll give him a try.
Anyone else got any ideas ?
Martinaston
To get this back to the top i'll explain the dillema and then maybe a few more people will show an interest
The reason i'm after the info is because i've found a set of 288 x 25 discs that will fit under the 15" BBS wheels and will either use the E32, E36/46 calipers or the M3 ones depending on which is the cheaper option.
So before i rule out the M3 does anyone know how they sit further out ? Hub
,carrier
or both
Martinaston
Mods could you move this thread to the motor sport section please because it doesn't seem to get much coverage here.
Thanks.
Thanks.
