Help with my 335i conversion.
mincedbeef
Post Fri Feb 16, 2007 10:49 am
Finally getting under way with my conversion, just finished getting the engine and wiring out of the doner car last weekend.
Theres a few bits i'm not sure about.
I got my engine mounts the other day but wanted to know what rubber mounts anyone has used under the engine mounts.
What water pump and power steering pump i need to use.
The engine came from a 87 735i.
Gary
DRIFTBOY
Post Fri Feb 16, 2007 12:14 pm
Hi Gary!
735i pas pump is fine - I converted a 325i and the pipes needed no modification to fit (not sure if it's the case for four cylinder cars ?), water pump is fine but worth fitting a new one - they are known to fail and are quite cheap.
I used new standard E30 M20 engine mount rubbers and gearbox mount rubbers.
If your 735i was an auto then remember to fit a spigot bearing in the crankshaft!
Martin.
mincedbeef
Post Fri Feb 16, 2007 12:25 pm
Hi martin,
Thats all good then. Its ok the engine is going into a 325i cab.
Cheers for the info mate!
I'll be putting my progress up soon.
Gary
DRIFTBOY
Post Fri Feb 16, 2007 12:28 pm
No problem,
I look forward to seeing the pics! :cool:
Good luck!
Martin.
