Accelerator Pedal Hell
beavis2k4
Post Wed Apr 06, 2005 2:54 pm
Hi Folks, GREAT site.
I just bought a 1991 e30 318is yesterday (Pictures coming soon) and need to do some minor repairs, one for example is the accel pedal...its sitting in the passenger seat. it looks as though it should be hinged by the plastic to the floor and a clip on the actual steel pedal but not sure, if someone could post pictures to show how it should be that would be brill. Thanks in advance,
Beavis
Jesus325iTouring
Frog freak !
Frog freak !
Post Wed Apr 06, 2005 11:28 pm
I'll whack you a picture tomorrow if you like :D
PS Welcome to the fine world of all things E30 :D :D
Post Wed Apr 06, 2005 11:49 pm
You're supposed to replace the accelerator pedal with a new one if it's removed for any reason. Just pushes and clips into the metel frame on the floor, and is held onto the linkage by a circlip.
Before you push it back in, decide if you want to remove the carpet for anything, as it has to be removed for this.
In practice, as long as the hinge is OK, and the plastic retaining clips are undamaged, it is OK to reuse it.
beavis2k4
Post Thu Apr 07, 2005 1:05 am
Thanks Jesus325 that would be good :)
Oh well looks like its broken, anyone know if you can still buy them? Circlip seems to have disappeared as well? There is also a large bolt behind the pedal sticking up through the floor and am not too sure whats its for, i will post pics asap and maybe someone will be able to recognise it. thanks,
Beavis
scintaar
Post Thu Apr 07, 2005 4:16 pm
Scrappies!! cost you about a 5-er!
Post Thu Apr 07, 2005 6:33 pm
Most parts for E30s are still available - maximum wait of 24 hours usually.
Large bolt is the adjustable stop for the throttle pedal.
Have never priced a new pedal, but I would be suprised if it came to more than a fiver brand new from the dealer.
Russ
Post Thu Apr 07, 2005 9:35 pm
scintaar wrote:Scrappies!! cost you about a 5-er!
But that wouldn't be for a new one would it? :stupid:
318iS became MR2 Turbo became FTO GPX Mivec became Impreza became Rover 620Ti became Honda S2000 (current) became Fiesta 1.25 and 200SX Drift Slag (when the Honda has gone)
Beanie2
Post Thu Apr 07, 2005 11:17 pm
Ԛ£13.92 for a new one
part: 35411156488
:wink:
Post Thu Apr 07, 2005 11:38 pm
Ԛ£13-92? Maybe your right, but that seems a lot for a single piece of plastic.
Russ
Post Fri Apr 08, 2005 6:58 am
Brianmoooore wrote:Ԛ£13-92? Maybe your right, but that seems a lot for a single piece of plastic.
Welcome to BMW ownership.
scintaar
Post Fri Apr 08, 2005 4:08 pm
Nothing wrong with getting one from a scrappies... I did and it's fine! Little soap and viola!!
scintaar
Post Fri Apr 08, 2005 4:11 pm
I would HARDLY think one would go to a SCRAPPIES for NEW parts...
naylor04
Post Fri Apr 08, 2005 4:39 pm
:tongue:
Russ
Post Fri Apr 08, 2005 7:26 pm
Even though
Brianmoooore wrote:You're supposed to replace the accelerator pedal with a new one if it's removed for any reason.
:bla: That was my point. He needs a new part.
Jesus325iTouring
Frog freak !
Frog freak !
Post Fri Apr 08, 2005 7:34 pm
Here the piccies,hope they help :D
This is the top connection closest to the underside of the dash...
and this is the top of the accelerator pedal.....
Demlotcrew
Post Fri Apr 08, 2005 7:44 pm
Who da man?
:jesus:
Jesus325iTouring
Frog freak !
Frog freak !
Post Fri Apr 08, 2005 7:48 pm
Demlotcrew wrote:Who da man?
:jesus:
Not the man thats in charge of hoovering my floor thats for sure! 8O
Why does everything look so manky close up! :lol: It doesn't look like that if your just sat in the car!
beavis2k4
Post Fri Apr 08, 2005 8:32 pm
Thanks for all the help folks,
I'll find the number for my closest dealer ( i live in the middle of nowhere) and order one. It has been said that i need to lift the carpet up to put the pedal in, does it just slide in under the holder ?
Post Fri Apr 08, 2005 9:45 pm
Don't need to lift the carpet up to fit the pedal - it clips in through the carpet.
You do, however, need to remove the pedal to lift the carpet. So anything you want to do under the carpet (e.g. check for rust), do , before you fit the pedal.
