do i realy need this????
appletree
Post Thu Feb 15, 2007 9:50 am
the problem i have is that this set up is right were i need to put things for my supercharger set up. I was trying to move it to bellow the black box in the pic but its going to be very difficult and still might not all fit so i was woundering it i actualy needed it??
coolent runs through the ally tube in the centre and heats the air running through the rubber tubes. one side is the feed from the cam cover breather to the inlet and the second is the the feed for the ICV.
i persume the idea is just to help the air engine heat up on start up.
so... is there any reason why i can just take it out and link the ally tube and then make seperate connections for the rubber inlets i a better position??? :D
Demlotcrew
Post Thu Feb 15, 2007 10:38 am
Come on mate there is no way that alloy pipe is there to heat the air travelling through the rubber pipes.
The answer to your question is that yes you can do away with it and just run a pipe from the external block water jacket to the cylinder head water port.
HTH
Andrew
appletree
Post Thu Feb 15, 2007 10:50 am
well why would bmw have gone to all the trouble to make the coolent run through the pipes reather than just link the ports together if it wasnt to heat up the air??? the rubber catings are quite intricate for them to be doing nothing :? .
what do you think there for?? :D
Demlotcrew
Post Thu Feb 15, 2007 1:57 pm
BMW did it because that section needed support in order to keep the breather pipes fixed in the correct position under the throttle body.
The actual metal part 'locks' the rubber pipes.
1. why would heating the ICV air after the ICV and after the throttle body be of any benefit to the way the engine runs?
2. why would heating the crank case vapours be of any benefit? (maybe to keep the vapours suspended to keep them from condensing inside the pipes) but the contact patch for this to work would need to be more than a few square centimetres. )
The need for 'hot' water to reach the throttle body heater plates was because in some of the colder countries the butterflies would freeze up and lock in position, so BMW put these heaters on the bottom and on the later cars on the back of the throttle body.
It would never be a problem in this country so you can get rid of all the water pipes there and just run a line from the external block jacket to the little input in the cylinder head.
HTH
Andrew
appletree
Post Thu Feb 15, 2007 2:31 pm
cheers, i just thought it was a funny thing to do. :D thought it might be just help things warm up on startup and to keep the vapours suspended like you said.
its all linked up now, nice and neat and out the way!! :D 8)
stuartgallafant
Post Fri Feb 16, 2007 10:47 am
so did you get rid of it then matt?
im thinking about doing this with my rebuild lump if its not really needed...
