my car has been sat for a few months now.........went to it today and the clutch pedal had no pressure on it! has the fluid leaked out or something???? where do i top it up????? is it likely it'll need bleeding?????
any help appreciated!!!!!
cheers
WHERE'S MY CLUTCH GONE?????????
danger_mouse
Is there hydraulic fluid in your footwell?
if not it's most likely slave cylinder rubbers... (open to more knowlegable suggestions though)
The slave cylinder is down under the starter motor if it's same as mine.
Check for and signs of sludgey leakage around the operating arm boot . If it's the Slave it should be an easy/cheapish fix.
Pray it's not the master cylinder as I'm guessing that will be a far more involved fix.
Never mind fluid in the footwell - Is there any in the resevoir? Small container hanging off the front right suspension turret.danger_mouse wrote:Is there hydraulic fluid in your footwell?
If it's empty then either the master or slave cylinder has failed. They should be replaced as a pair.
