Imobiliser and tow-eye distress!
danger_mouse
Post Wed Feb 14, 2007 3:20 pm
Hi guys,
post #1, I'll understand if this sounds suspicious, so I'll introduce my self a bit first.
Will sort my profile ASAP!
My name's Dave Martin (D.M. hence "danger mouse") and this is the "Red Baroness" or simply the "Bavarian" as she's sometimes known ('91 E30 320i Touring)...
...sat with one of her old friends.
I have had quick scan through the forum and didn't see the answers I am looking for straight away so here goes...
I've owned her for six or seven months now, but never run the battery down.
Now after not being used since the new year, for cash flow reasons (her friend is the clue to why :wink: ) I thought I'd take her for a spin to make sure she doesn't seize up completely.
Not suprisingly she needed a just start, but our other pet (3cly Swift) gave a her the kiss of life and all was well. Fired up first swing. 8)
Ran her to the localist petrol station for a splash of juice, tanked her up, went to fire her up and nothing.
OK, battery's still dead... asked a kind chap for a jump (I brought the leads with, just in case of exactly this) all the electrics respond, good, turn key to postion iii... absolutely nothing.
Oh good.
:o:
When the guys at the petrol station attached a heavy duty jumpstarter suddenly the alarm goes off.
That was a suprise, as the alarm has never done anything before, so I just assumed it was out of commission. Now, doing its best impression of a stuck pig, I can only guess (after checking all fuses and relays) that the imobiliser circuit is the reason the engine won't turn over.
:x
Looking in the owners handbook, there is reference made to a "Magnetic Coded Key". Such a thing never came with the car, but is one of these my only hope starting the car up again without butchering the wiring looms? If so where can I source one without a bankloan? :eek:
To add insult to injury, I was ready to take up the kind offer of a tow back to the house when a look through the otherwise complete tool kit, revealed no towing eye.
Great.
:cry:
Are towing eyes availible from autofactors, or even does anyone know if the E30 one uses the same thread as a SmartCar???
I could lay my mitts on of those quite easily. winkeye
Right I'll sort out my profile now.
Cheers for any advice in advance even if it just a direction to any threads covering these problems...
DM
eko
Old timer
Post Wed Feb 14, 2007 4:48 pm
Hi Dave,welcome to the zone!
Well probably absolutely no help here but ill try.
Is the an after market alarm or immobiliser fitted?
Have you checked for spark/fuel?
Can you hear the fuel pump prime from under the reae seat when you switch the ignition on?
Oh and think ive got a towing eye here,PM me if you want it!
danger_mouse
Post Wed Feb 14, 2007 5:32 pm
I was hoping I could get my hands on towing eye like tonight, so I can bring the old gal back to her stable really. but cheers for the thought.
Will see if the Smartie one goes in the 'ole when my housemate gets back.
With the jumpstart pack attached to the battery terminals, everything seemed normal except the lack of startermotor engagement... oh and the wailing alarm which has never even peeped until now.
It looks like a factory fit alarm/imobiliser, as all the looms are integrated with the rest of the car's wiring so if it's an aftermarket it's a very pro' job.
My guess is, as I havent ever had the magnetic code key, I have simply never activated/armed the alarm before, and leaving it flat for a while, and now jumping it has riled it.
The wierdest bit is that it let me jump it in the first place then only threw a wobbly we I came to re-start it on the other side of the village!
:eek:
danger_mouse
Post Wed Feb 14, 2007 5:38 pm
By the way chaps, I understand perfectly if you won't tell on a public forum how to sort this issue, but if you do have any "Tricks" please PM, before I end up as bald as my old dad...
Northern Biligerance Cannot be Learned, but it Can Sure as Hell be Appreciated
eko
Old timer
Post Wed Feb 14, 2007 6:06 pm
Dave best advice i can give is hang on untill BrianMoore reads this,hell soon talk you through it!
Maybe edit your title to include his name and FAO?
If it is a standard BMW alarm you shoulhd have the alarm remote fob?
danger_mouse
Post Wed Feb 14, 2007 7:30 pm
Cheers EKO,
Sorted for a towing eye now, if nothing else, at least she'll be home tomorrow.
Then I will be able to go over it all without numptie greasemonkies telling me
"Er, you can't tow it by the front cross member, the turney roundy (I kid you not!) bits will shread the ropes and pull the front off the car"
"What, the driveshafts...?"
"Yeah, that's it."
"Oh, all right then"
:eek: :roll: Image
Be afraid... be very afraid!
Post Wed Feb 14, 2007 7:51 pm
Length of wire, croc clip on each end. One croc clip on coil + terminal, other one on battery +. Try starter.
If it won't crank, then starter circuit is immobilised as well.
Take top off the diagnostic socket (top, left front of engine), and identify pins 11 and 14. When you're sure you know which ones they are, jump them together with a short piece of wire to engage the starter motor.
It is possible to install a more secure immobiliser on an E30, but most can be defeated as easily as above.
If you have to tow without a towing eye, then remove the bumper (two large torx bolts up through the bumper from underneath, then just pull forwards), and use one of the bumper mounts to attach the tow bar/rope.
danger_mouse
Post Wed Feb 14, 2007 7:58 pm
Brianmoooore, you are a god!
Thank you. I will go and shock the numpties with this new found knowledge in morning.
Brilliant!
DM
