clunking noise on startup m40
bigmattpowell
I get a sort of metallic "dunk dunk dunk dunk dunk" noise sometimes on startup, probably about 5 times per second roughly. Usually only lasts for a second or so but sometimes longer coming and going, a quick blip on the gas usually sees it off. Sounds like it's coming from the bottom of the engine or box. No difference with clutch in/out or in gear/neutral. Other than that, pretty smooth strong m40, any ideas?
Not coming from where you say, but it's not unusual for the hydraulic tappets to tap for a few seconds after startup.
Not unusual for them to continue tapping on a M40, for that matter.
