Bleeding Brakes
bigdek
Post Tue Feb 13, 2007 4:10 pm
My sport failed its mot on 2 brake pipes which i'm quite happy with.
I've just fitted new bmw ones to the nearside front and the long one that runs from the front to the t piece beside the diff.
What order do i bleed them in . ?
do i need to do all 4 calipers ?
DRIFTBOY
Post Tue Feb 13, 2007 4:18 pm
Probably worth doing all four, it's not much effort and a good time to renew the fluid anyway.
Normal procedure is to start with the wheel furthest from the master cylinder (rear right hand on E30) and finish nearest the cylinder (front left).
Pressure bleeding them is much quicker and easier, and the kit is quite cheap from most motor stores.
Martin.
bigdek
Post Tue Feb 13, 2007 5:12 pm
never heard of pressure bleeding . how does that work ?
DRIFTBOY
Post Tue Feb 13, 2007 5:25 pm
The most common one is called 'Eazibleed'.
A bit hard to explain but it comes with two bottles connected with a pipe. Another pipe attaches to a wheel tyre valve (where the pressure comes from). One of the bottles is filled with brake fluid and then a cap with a tube to one of the bottles screws on to the top of the brake master cylinder. It's easier to understand when you look at the kit!
You just go round and undo the caliper bleed screws, no need for all that pedal pumping!
Only thing is, you must do up the cap on the master cylinder very tight or fluid will spray everywhere ! 8O And you'll probably need to pump your tyre up slightly after using it, but it's worth it!
Martin.
