Hi as u have read, my front fogs dont seem to work. i changed the bulbs and they worked for a bit if i hit them but know they wont come on at all, the fuses are fine just wondering if any one had any thoughts.
FOGS DONT WORK!!!!!!!!!
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
do you have a multimeter so you can check continuity? could be a break along the wire somewhere?
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
sam325is
could be rusty wires where they go in to the connector plugs that go into the back of the lamps.
GBE30
Try changing the switch, pennies on ebay and they sorted mine out when they stopped.
E3OSAM
cheers for the advice i will hopefully try that lot 2moz
OLD SKOOL
nickso
- Location: Go do that voodoo that you do so welllllllll!!
take the switch apart...they go really green inside for some reason.
'88 e30 328i M52 track bint.
More random part swapping advice instead of testing! Cure one fault - cause five more!!!!
Does the fog light warning lamp in the instrument cluster light? If not, pull out the fog light relay, K8, and connect a piece of wire between battery + and pin 87 of the relay's socket. Do the foglights work with this in place? Does the warning lamp light up now?
Turn the foglights on. Does relay K8 click as you pull it out and push it back in?
wildeian
It's called 'verdigris'
Verdigris is the common name for the chemical Cu(CH 3 COO) 2 , or copper(II) acetate. It commonly occurs by the action of acetic acid when copper, brass or bronze is weathered and exposed to air or seawater over a period of time.
Had it in mine too, opened switch, cleaned it out and all worked fine!
