M42 misfire / fuel problem?
aretha
Post Sat Feb 10, 2007 9:33 pm
I have recently purchased a 1990 318is baur convertible, mileage 72,000 with full history. I love it! I had it serviced (independent specialist) plus additional work. Shortly after the service, an engine misfire occurred which seemed to be fuel related and the mechanic suggested fuel additive cleaner might help and he recommended the higher octane unleaded. I did both, and the misfire seemed cured. But it's come back. Perhaps because I did not continue with higher octane fuel, nor did I use the fuel additive on last fill up as I thought the problem was solved. In addition, I think it happens when the tank is low / a quarter full and after a period of 60/70mph driving on motorway. When I turned it off last night the misfire was present but this morning, it started without the misfire. It is intermittent within a phase of misfiring, and then has run for 2 tankfulls without any difficulty. Any ideas? :?
E30Mark
Post Sat Feb 10, 2007 9:54 pm
Welcome, a rare beast the 318iS Baur, only know of about 4! :cool:
Mis-fires can be so many things... the easiest place to start is to change the blue temp sender (under the front of the inlet manifold, about £10 - £15) the Airflow meters (AFM) can also be a trouble spot...
Next time the mis-fire happens, leave the engine running and remove the petrol filling cap, any sudden gush of air will indicate a blocked fuel pipe.
Where about are you? maybe a friendly local could take a look, and or swap some known good parts with you.
Best of luck :cool:
PM for details
aretha
Post Sat Feb 10, 2007 10:02 pm
Thanks for advice, will try your suggestions :) - not that far from you! Romsey, Hampshire.
E30Mark
Post Sat Feb 10, 2007 10:45 pm
I know of 2 318iS Baurs in this area, a red one (knackered...) in Ferndown, and a red one near Ringwood...
Come along to our next meet (Missed the meet today!) we can all take a look and give you dozens of different answers 8)
PM for details
aretha
Post Sun Feb 11, 2007 7:35 am
thanks again, maybe will get to next meet. Mine is white!
Also would appreciate advice about good, value for money person to get rid of some small rust around wheel arches.
stuartgallafant
Post Sun Feb 11, 2007 12:17 pm
using a higher octane fuel wont cure your problem, as the DME is not mapped to use that type of fuel. if you took it for a service and then it developed a misfire, i would be taking it straight back to the place it was serviced at...
M42's dont really have a common misfire problem, howver, there are a few things that often occur, causing problems...
check the state of the camshaft and crankshaft position sensors and their leads. problems with these will cause engine misfire. dont confuse a misfire with an air leak either. a lot of people do, so check all the inlet bellows for splits and tears and view the manifold gaskets too
however, your problem sounds more fuel related, in a way of possibly blocked or dirty injectors. also, just from your description it sounds like your tank might be full of sh!t too
do a few checks and start defeating possibilties before you start shelling money out on replacing things you dont have to
:thumb:
aretha
Post Sun Feb 11, 2007 1:36 pm
Thanks for comments and good advice and will check as you suggested. I definitely think you are right about the tank as car had periods of not being used much in last few years.
