Screenwash (intensive wash)
jcjdavis1
Hi I put my screenwash back together today but when I lift lever for wash nothing happens but when I push the end I get a jet of water on the screen.Any ideas folks.
Chris-W
Your E30 has two completely seperate screenwash systems. The only thing they share is the washer jets.
Sounds like the intensive wash is working, but the ordinary screenwash isn't.
Simple enough circuit - Ignition switched live to one side of the pump motor, and the other side is earthed by the washer switch.
jcjdavis1
Thanks gents I will have a look tomorrow.
jcjdavis1
Hi Guys I have swapped over relays and checked fuse but still no wash/wipe but have intensive wash/wipe.I will check pumps when I eventually get car to my work.I was wondering if this box has anything to do with it as it is coming apart at the base and possibly got water inside and is located beside all wash electrics.If not what is it for?
rj
That is an integral part of the headlight wiper/washer system.
jcjdavis1
Hi thanks I hope it's not goosed.
buster
Ive got a spare one if it is,just give me a shout
jcjdavis1
Hi buster I am just getting the car on the road after head change and am now finding all these little probs.I have put two working motors on the h/wipers but I have not tried them yet.PM me a price for the part I might as well get one. Jim
buster
you can have it,pm me your address and i'll remove it from the bottle and send you it
jcjdavis1
Hi Buster PM sent and thank you very much TOP BLOKE.
d6dph
That's why I love this placebuster wrote:you can have it,pm me your address and i'll remove it from the bottle and send you it
That "relay" is for the intensive wash/headlamp wash/wipe system, and is nothing to do with your problem.jcjdavis1 wrote:Hi Guys I have swapped over relays and checked fuse but still no wash/wipe but have intensive wash/wipe.I will check pumps when I eventually get car to my work.I was wondering if this box has anything to do with it as it is coming apart at the base and possibly got water inside and is located beside all wash electrics.If not what is it for?
There are no relays or other little boxes involved with the operation of the screenwasher - just the pump and the switch.
Stop looking for random things to swap and TEST.
Check for 12V ignition live at one side of the washer pump, purple/black wire, or earth the brown/black on the other side of the pump.
jcjdavis1
Hi Brian I will check pumps later.I thought the wiper should work even if the pump does'nt.
PS I would love to read what you say to other team members about us dumplings who keep rambling on.
old_skool
I would expect harsh explicit contentPS I would love to read what you say to other team members about us dumplings who keep rambling on.
jcjdavis1
Hi I took off wiper stalk and you can see the contacts work when you pull stalk,so I cleand contacts and sprayed with WD and wash/wipe is working now.thanks for help.
buster
Do you still need this module.I am just about to post it now actually.
jcjdavis1
Hi buster I only got windscreen wash working.So please send if possible many thanks Jim
buster
ok,np
