right side of the dash?
eoin0706
Post Fri Feb 09, 2007 8:04 pm
the right side of the dash is not lit up and there is a wire hanging down from under the dash,any ideas if this is the problem? and where it should go?http://i164.photobucket.com/albums/u6/x ... m_dash.jpg
eko
Old timer
Post Fri Feb 09, 2007 8:05 pm
That plug looks like its for the gong from the OBC?
Ant
Retired Team Member
Retired Team Member
Post Fri Feb 09, 2007 8:06 pm
that plug is for the OBC gong dude, nowt to do with the lighting issue
Chances are one of the cluster bulbs is out/blown, pull the cluster and have a tweak dude
HTH
Chris-W
Yep - looks like OBC gong. The illumination problem will be one of the two main cluster bulbs.
eoin0706
Post Fri Feb 09, 2007 9:24 pm
thanks for the feed back people,could anybody tell me how to go about getting to the main cluster, to replace the bulb? and if i have to get it from bmw?does anybody know where i plug the gong into obc,ie where in the dash its supposed to go?thanks eoin.. :P
jcjdavis1
Post Fri Feb 09, 2007 9:31 pm
eoin0706
Post Fri Feb 09, 2007 9:39 pm
sound jcjdavis1 shall give this a go!
