exhaust swap
salami
Post Fri Feb 09, 2007 6:47 pm
i have a scorpion pipe on from half way down the car and need to know if a standard end can will fit the pipe work.
thanks
Ant
Retired Team Member
Retired Team Member
Post Fri Feb 09, 2007 6:51 pm
assuming from your description you have the later 2 part zaust.
If that is the sace, a stock 2 part rear section will swop in without issue, if you have the 3 part system, you can swop the B/Box on its own, the link pipes are seperate.
salami
Post Fri Feb 09, 2007 7:08 pm
thanks Ant
