Best regards, Goosie.
14" BBS tyre pressures for the foul weather?
goosiegander
- Zonegoose
Just a quick query, should i be running on slightly reduced tyre pressure with all this crap on the roads? Common sense to me says probably yes, however, any recommended pressures for 14" wheels?
Cava
I've always gone for the standard 1.9 front / 2.1 rear (bar) on my winter 14" set - seem to work ok. Lower pressures are a good idea where the tyres are going to heat up a lot (i.e. track day) but probably not the best for cold weather.
Hope this helps!
Hope this helps!
goosiegander
- Zonegoose
ok cheers man! much appreciated
