injector cleaning
exup
Boost Junkie
Post Fri Feb 09, 2007 3:11 pm
Hi
whats the best method to clean up fuel injectors , ,
i thought about removing them and leave in injector cleaner over night , and use tooth bush on tip end or , use a 9v battery to open them and flow cleaner down them ??????
any tips or best cleaner to use ?
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Fri Feb 09, 2007 3:45 pm
best (but most expensive way) is to get them sonically (spelling?) cleaned.
could try your nearest technical college, when I did my HND in Automotive engineering, part of the course included testing injectors, cleaning them with a sonic cleaner then testing again. So the uni needed 6-8 cars per year to test so they got them cleaned for free!
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
smithy318i
Post Fri Feb 09, 2007 4:10 pm
I recently cleaned my injectors by soaking them in carb/injector cleaner, then feeding pressurised cleaner through them while intermittently applying 12 volts to them. The resulting spray patturn was quite pretty.
These are the only pictures i could obtain from the video i made.
exup
Boost Junkie
Post Fri Feb 09, 2007 7:57 pm
that was along the lines i was thinking , i wondered if paint thinners , or elctrical contact cleaner would also be any good ?
