has anyone ever managed to
dazleeds
old skool raver
old skool raver
Post Fri Feb 09, 2007 2:54 pm
fix a buggered sunroof drain tube??
theres no rot etc
so im guessing that either the tube has disentegrated or come loose maybe??
anyway the water comes in thru the inner sill if you pour it down the sroof drain tube
any ideas/ experiences??
Daz
www.oldskoolfantasy.co.uk
suzie650
Post Fri Feb 09, 2007 4:26 pm
Blocked drain? Then the solution might be to clean it with some sort of stiff wire.
... I'm saying that, but still haven't got round to do mine. I drilled a 6mm hole :cry: in my side pocket instead. Bodge, but at least I don't end up with swimming pools anymore, untill I find the right wire for the job.
dazleeds
old skool raver
old skool raver
Post Fri Feb 09, 2007 4:32 pm
sadly no blocks
done the wire trick
i think its because i had a small plate put in the floor and this has started since then :roll:
so im guessing he either managed somehow to melt the tube??
or the fact that he plastered saler everywhere underneath may have caused it
to fill the tube and its popped off :cry:
gonna get rid of the sealer but i dnt think this will solve it
so i need to know how to change the tube i guess :?
Post Fri Feb 09, 2007 4:34 pm
drill the floor daz :mad:
TAXI!
Geeman
Post Fri Feb 09, 2007 4:37 pm
You could fit a drain and plug from your kitchen sink and have one of those pop-up levers to open and close it at will. How trick would that be? The chicks would love it. Cool. 8)
:wink:
dazleeds
old skool raver
old skool raver
Post Fri Feb 09, 2007 4:38 pm
E30BeemerLad wrote:drill the floor daz :mad:
TAXI!
noooooooooooooooooooooo :cry:
you know im determined to do things properly on the sport :wink:
oh well i'll have a garage in a week so she will be getting pulled to bits asap winkeye
block n head are off for maching asap
big tings a guaaaaaaaaaan as we say in hackney :rasta:
dazleeds
old skool raver
old skool raver
Post Fri Feb 09, 2007 4:40 pm
Geeman wrote:You could fit a drain and plug from your kitchen sink and have one of those pop-up levers to open and close it at will. How trick would that be? The chicks would love it. Cool. 8)
:wink:
:screwy: but i get your thinking winkeye
Post Fri Feb 09, 2007 8:18 pm
:wink:
you could make it work with your handbrake, clutch pedal or even say the indicators. This way it would keep on top of things and save you extra work?
Must be the tech 1!
