Front end crash repair questions
TaitRacing
Post Fri Feb 09, 2007 12:53 pm
Crash repair
I slid into a post last night at about 10mph (sheet ice) and my lovely '85 2-door now looks terrible.
It needs a new n/s front wing, chrome bumper and lower valance/front panel that sits behind bumper.
Does the mentioned front panel come off with ease and if I were to fit later bumpers, could I do away with it completely? Also, do you know if the S2 bumpers are lighter than the S1 comination?
whipsey
Post Fri Feb 09, 2007 12:56 pm
the front panels are all bolt on you can update the front bumper to a face lift one all you need is the front bumper brackets for the side and the two behind the bumper you will have to get the grinder out to the origional towing eyes though as the updated bumpers nedd that space to get the bolts in
whipsey
i think i might even have a replacement front panel for an early one as well as a panel for a face lift
Theo
Post Fri Feb 09, 2007 1:04 pm
The front valance is really easy to swap over, only takes a few minutes really. I have a good one if needed.
Changing to later plastic bumpers will not give you any weight advantage, they are heavier than the metal ones. Plus is will make a nice original early car look a bit dodgy IMO.
TaitRacing
Post Fri Feb 09, 2007 1:22 pm
Hi chaps,
thanks for the replies.
Whipsey, thanks for the info, it sounds like Theo has a front panel too and he seems to be closer to me than Kettering. So I'll see what he says first.
Theo, I've sent a PM regarding the front panel.
whipsey
Post Fri Feb 09, 2007 1:23 pm
not a problem
