318is diff oil???
P_VIDDY
Post Fri Feb 09, 2007 11:04 am
Hi
i am servicing my 318is. What oil do i need for the diff???
thanks
Templ8e30
Post Fri Feb 09, 2007 11:05 pm
If you have a limited slip diff then you need the special diff oil from the BMW dealer, it's pricey at about £18 per litre but it is the correct stuff.
If it's a standard open diff then you'll need some SAE 90w hypoid gear oil, make sure you get a good name brand (ie castrol or silkolene etc).
With it being a 318iS it should be a small case diff (6 bolts on the rear cover) so you only need 0.9 litres.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
sam325is
Post Sat Feb 10, 2007 12:31 am
LSD oil isnt to pricey if you buy it from opie oils (oilman)
castrol saf xj is £9.99 per litre from them. this is exactly what BMW use on 325is LSD's
Templ8e30
Post Sat Feb 10, 2007 1:29 pm
BMW don't use SAF XJ, they use SAF XL according to my receipt 8O
Dunno what the difference is though ?
Cheers,
Iain T
sam325is
Post Sat Feb 10, 2007 2:22 pm
lol well each dealership must use a different type. cotswold bmw use saf-xj on 325is LSD's. is yours a 318is or 325is.
either way opie oils will sell it for 9.99 per litre :D
