hi guys,
i fitted e36 m3 sports seats in my e30, these are the wide(wider than standard e36 seats) bucket seats that are electric. yep... power seats..
up down tilt up tilt down and recline.. all electric..
So, the seats are installed and in.. and my gosh... so much more
comfortable than the e30 seats!!!! especially for me, ime 6"4
anyway... we worked till 2am this morning getting the buggers in..
still some tweaking to do..
basically... something very basic and probably very important that i didnt check was the safety belt buckle.. it doesnt click into the e36 m3 seat..
this particular e36 m3 seat has a safety belt tensioner(currently disconnected) its a safety feature that basically automatically tensions the safety belt in the event of a accident.
also, the other side of the safety belt.. the bar with the belt attached to it is currently mounted on the seat.. this has very little clearance.. it could be bent a little..
so i have 1 of 2 options:
1) remove the whole e36 safety belt socket and tensioner thingy etc and fit the stalks from the e30.
2) fit a complete e36 safety belt reel..
now for my next question,
does a e36 safety belt reel bolt straight onto a e30???
the thing with option 1 is this, Its like quite a big piece with a plastic thingy attached on the side of the seat (probably the mechanism for the tensioner)
and it kinda forms part of the seat, so i would have to remove it...but i suspect it wont simply be a bolt or two... i might have to cut some of it off.. the plastics that is.. i could always fabricate a new kinda cover or something..
has anyone here done a similiar conversion???
i presume the regular e36 seats use the same safety belt thing? but this is just assumption and we all know what asumption is... the mother of all f*ckups.
cheers
Anton
fitted e36 m3 sport seats in my e30-safety belt issues.help
anton
Ant
- Retired Team Member
dude pull the trim off and you'll see the pyro belt tensioner will come away from the seat pretty easily, for fun connect a 12V source to the terminals, but make sure and be 10 feet away when you do
Swop in the E30 belt clasp and job jobbed. anchorage point is plenty strog enough.
Email FTW
