speedo problem ???
yetti24
my speedo has been playing up for a while sometimes working sometimes not on my m3 , i have changed the sdiff sensor and rewired from the rear beam to the diff and now the speedo does not work at all , i have a negative feed from the plain brown wire but no negative or positive feed from the brown wire with the red stip , does anyone know how it works is it a negative curcuit or should there be a positive and negative feed to the diff sensor , please help i am having a nightmare with it !!!!!!!!
eltel
not sure about the feeds etc but mine played up intermittantely then stopped... i had to replace the speedo relay in the engine fusebox on n/s wing..might be worth checking that all relays etc are pushed in correctly and that no water has got into fuse box???
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
yetti24
THANKS FOUND OUT IT IS A NEGATIVE CIRCUIT AND THAT MY SPEEDOMETER UNIT IN THE CLUSTER WAS FAULTY SO I REPLACED IT AND THAT HAS SORTED IT ( IN CASE ANYONE HAS THE SAME PROBLEM ) I GOT THE SPEEDO CLUSTER FROM A 320I CLUSTER REPLACED THE THE NEEDLE AND SPEEDO FACE . THEY SEEM TO BE ALL THE SAME ACROSS THE E30 RANGE , HOPE THIS HELPS
