Main earth points
carlos_320i
Post Thu Feb 08, 2007 9:59 pm
Can some one tell me where the main earth points are on a 320i as I have a bad one somewhere and need to get it sorted
Thanks peeps :D
Post Thu Feb 08, 2007 10:19 pm
Just behind left headlamp, RH suspension turret, above glove box and LH side of rear seat pan.
Also a minor one at the top of the steering column, and the main engine to body earth strap.
carlos_320i
Post Thu Feb 08, 2007 10:37 pm
Thanks mate just what I was after :D
carlos_320i
Post Fri Feb 09, 2007 4:59 pm
Ho mate when you say rear seat pan is that under the seat or on the floor :? behind the drivers seat
Post Fri Feb 09, 2007 10:54 pm
carlos_320i wrote:Ho mate when you say rear seat pan is that under the seat or on the floor :? behind the drivers seat
Under the seat cushions. Up above the rear left wheel arch on tourings.
carlos_320i
Post Sat Feb 10, 2007 1:27 am
Ok thanks mate I will have a look in the morning and see if I cant find this bad earth :mad: as it is now doing my head in
Post Sat Feb 10, 2007 9:47 am
What makes you think you have a bad earth?
carlos_320i
Post Sat Feb 10, 2007 10:15 am
The OBC and the rev counter and the MPG and the interior lights have stopped working and if I pull the front door switches off and join the wires together they start to work again :?
Post Sat Feb 10, 2007 10:26 am
Earth point for OBC and instrument cluster is above the glovebox, but it's more likely to be the SI board batteries are failing.
Door pin switches are earthed by the screw that holds them to the door pillar.
carlos_320i
Post Sat Feb 10, 2007 10:34 am
I have swaped the clocks with a spare set I have out of my old E30 whitch I know they worked. What are the batteries like as I might change that anyway :?
DaveD
E30Zone Wiki Specialist
Post Sat Feb 10, 2007 11:01 am
there used to be a how to do this on the total bmw site but that has gone ...you get the batteries from maplins and
this is a how to...if you want a better guide i think i downloaded it on my work computer...let me know if yoou want it
http://www.pelicanparts.com/BMW/techart ... teries.htm
carlos_320i
Post Sat Feb 10, 2007 11:07 am
Thanks mate I will do that next week when I am at work :D and take a look at the earth point today if it stops raining :-x
Post Sat Feb 10, 2007 1:20 pm
carlos_320i wrote:and join the wires together
You say "wires" (plural).
The switch is a double switch, and doesn't join the wires together when you open the door - it connects both wires to earth independently.
Nothing should happen if you join the wires together, but if you earth one the interior lights should come on, and if you earth the other, your window/roof switches should light up.
Examine the switch carefully. It's common for a small piece of plastic to wear and build up just where the switch contacts are. Trim this piece of plastic away with a craft knife, clean things up generally, apply a little silicon grease and they'll be good for another fifteen years.
