Can a 320i wiring loom be used in a 325i (2.7)?
Jimbob
Post Tue Apr 05, 2005 1:51 pm
As topic says...any helpful input is appreciated, cheers.
Geeman
Post Tue Apr 05, 2005 1:57 pm
Yeah, it all can.
Ian is running a 2.7 in his 320... it's only the ECU that's different!
HTH
Giles.
Jimbob
Post Tue Apr 05, 2005 1:59 pm
Cheers Giles, shoulda remembered that his used to a 320!
Templ8e30
Post Tue Apr 05, 2005 2:17 pm
Yup, everything is identical bar the ECU.
Can't wait to finish running in so I can get her on a dyno, She pulls much stronger than I imagined she would :D
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Demlotcrew
Post Tue Apr 05, 2005 2:23 pm
I Think the ECU is the same also, just the EPROM is different.
Andrew
Templ8e30
Post Tue Apr 05, 2005 3:54 pm
Demlotcrew wrote:I Think the ECU is the same also, just the EPROM is different.
Andrew
Yes, spot on !
Cheers,
Iain T
gorgeee
Post Wed Apr 06, 2005 12:02 pm
what did you have done to yours Templ8e30?
did you do it all yourself?
Black Sport
