hey, im playing with the idea of stripping the interior out of my e30 to make it a bit quicker! Is there anything underneath or under the bonnet that can come out thats not important or should i just stick with the interier?
cheers jonathan
stripping an e30
BadMansWheels
get the air con / heater out of there, must weigh a few kilos.
jondrift
where is it located? sorry im new to these engines!
320Touring
Here's a little ditty I made up for my 318is
Stripping my e30 318iS
Carpets.
Door cards.
Glovebox.
Centre console.
Boot carpets.
Radio.
Soundproofing.
Move the window switches to the main dash board.
Install manual window winders?
Speakers.
Kick plates.
Head lining.
Rear shelf.
Belts.
Un-needed wiring for the radio.
All boot linings.
Drill the pedals.
Drill the metal work.
Drill front alance
Cut all extra length off bolts.
Drill Bolts and nuts.
Rubbing strips on the bumpers.
Trims on the doors.
Passenger wing mirror.
Central locking.
Sun visors.
Battery from the front to the back.
Bumper reinforcers.
Pin down hood and deleted hinge/hardware.
Pin down Boot and deleted hinge/hardware.
Shave flywheel from 30lbs to 17.
Delete spoiler.
Carpets.
Door cards.
Glovebox.
Centre console.
Boot carpets.
Radio.
Soundproofing.
Speakers.
Kick plates.
Head lining.
Rear shelf.
Belts.
All boot linings.
Drill the pedals.
Drill front alance
Trims on the doors.
Central locking.
Sun visors.
Bumper reinforcers.
Delete spoiler.
J_Mac
if powersteering, that can come out to, steering should still be quite light
there will be peeps along soon that do this stuff for trackdays
Chris-W
jondrift
cool sounds like a lot to do, still need it for some road use too thou, so wont be able to do two or three of thsoe
320Touring
lol! the one on the schhlaag was of no use anyway. boot used to pop open when you pressed the bootlock in...Chris-W wrote:And miss out on that negative lift????!!!320Touring wrote:Delete spoiler.
rear end on that barsteward needed weight putting back in to keep her from lifting
