first problem!
jondrift
Post Thu Feb 08, 2007 6:22 pm
righto, time to start burning money now! last night when i viewed the car (325i 1988) i thought it was very tidy and sounded smooth with no smoke or oil leaking, however 200 miles later, ther is grey smoke from the exhaust, wet oil on the inside of the exhaust, and a slight tappet sound from the engine :(
anyone know off the top of their heads what this is?
other symptoms are a slightly uneven idle and chokes a bit when you floor it (possibly oily spark plugs?)
cheers jonathan
jondrift
Post Thu Feb 08, 2007 6:30 pm
p.s. the smoke is not really bad and might just be showing up as its snowing! but the tappet noise and oily exhaust is my main concern??
jondrift
Post Thu Feb 08, 2007 6:38 pm
oh and it also has a light on all the time saying 'inspection'
Sanchez
Post Thu Feb 08, 2007 6:47 pm
jondrift wrote:oh and it also has a light on all the time saying 'inspection'
are there any service lights on?
jondrift
Post Thu Feb 08, 2007 6:48 pm
which are the service lights? there is a green light on just above the 'inspection' light on the clocks??
Sanchez
Post Thu Feb 08, 2007 6:54 pm
thats the ones. they are 5 green lights which are all lit when just been serviced.
Sanchez
Post Thu Feb 08, 2007 6:56 pm
might help
Sanchez
Post Thu Feb 08, 2007 7:00 pm
what lights are on?
Have you serviced it?
wildeian
Post Thu Feb 08, 2007 7:04 pm
Inspection light is an MOT reminder
Your other symptoms sound like valve stem oil seal need changing
jondrift
Post Thu Feb 08, 2007 7:14 pm
how much is a valve stem oil seal going to be?? does anybody do it??
i have 1 green light left, i am planning on doing a full service next week thou
jondrift
Post Thu Feb 08, 2007 7:22 pm
*meant to say can i get it done anywhere!?
wildeian
Post Thu Feb 08, 2007 7:28 pm
Valve stem oil seals involve taking the cylinder head off, and changing the oil seals on the valves (12 on your 325i)
So while the head is off:
-new cambelt & tensioner
-new water pump
-head gasket kit
probably a few other bits too
On the other hand you could be getting blow-by of the piston rings, where oil from the bottom of the engine is getting into the cylinder.
Might be best to have someone look at it first
jondrift
Post Thu Feb 08, 2007 7:41 pm
so still nice and expensive either way! ill have it checked out.
wildeian
Post Thu Feb 08, 2007 7:43 pm
are you burning a lot of oil?
jondrift
Post Thu Feb 08, 2007 7:49 pm
ive only had it one day, so not sure yet
