Alternator belt
tomski
Post Wed Feb 07, 2007 10:31 pm
Got myself a new alternator today and have been trying to fit it for the last 3 hours. The problem I am having is that when I get the belt on to the pulley its so tight I cant move the alternator enough to put the bottom bolt in. The belt had ---950 on it does anyone know if that is the right size belt for it. I fitted the last alternator and it went on ok. Iam thinking that either the belt is wrong or the pulley on the new alternator is too big
Car is a 1992 325
Post Thu Feb 08, 2007 12:55 am
325 alternator belt should be 9.5 X 965
tomski
Post Thu Feb 08, 2007 7:22 am
Thank you. Is it difficult to change the belt, I can see that the p/steering belt would need to come off. Can you fit the belt over the fan?
Post Thu Feb 08, 2007 8:48 am
Take the air filter AFM assembly off to make things easy to reach, then it's easy.
Steering belt does have to come off, and the belt goes over the fan OK.
Don't slacken the 13mm nut on the adjuster pinion too much, or the teeth on the 19(?)mm adjuster nut will slip off the rack and chew the teeth. Pivot bolts for the alternator and pump will have to be slackened and tightened afterwards.
