I think I might have a problem with my tps. I did a search a while back and found a post on how to do this but I cant find it now. I think it said to check for continuity across the middle pin and the one near to the windscreen when the throttle is shut and the middle pin and the pin near the front of the car for full throttle. Does this sound right
Cheers, Andrew
Testing TPS
rj
You're looking for:
0 ohms between pins 18 (middle) and 2 (left) with throttle closed.
0 ohms between pins 18 and 3 (right) 0 ohms with throttle fully open and an infinite reading between these 2 pins with the throttle just off idle.
Not quite right! This is the wide open throttle switch, and the switching point should be somewhere around 2/3 throttle, not just off idle.rj wrote:0 ohms between pins 18 and 3 (right) 0 ohms with throttle fully open and an infinite reading between these 2 pins with the throttle just off idle.
rj
The Burgess microswitch with throttle fully closed is at it's minimum detent position alongwith the contact points which are fully open at this stage, offering 0 ohms resistance. When the plastic cam is moved 1mm, via the throttle butterfly shaft, the anodised lever of the microswitch opens the contact and the points remain open, showing an infinite resistance. This ohmage reading is only finally altered when the cam moves fully anticlockwise, closing the points at full throttle, thus the ohmage should show 0 ohms.
The movement therefore should show infinity from just off idle, hence the audible "click" to almost fully open throttle and not just at 2/3 open as the microswitch is purely a switch and not of variable resistance and purely triggers the AFM to take over from the ICV for fuelling requirements. The final movement of fully open is reflected by the points closing and not the switch.
So in conclusion, closed throttle 0 ohms, just off idle to almost fully open, infinite resistance and 0 ohms at fully open, as earlier stipulated.
tomski
Thanks I will check it and see what I find it.
