Please help ! - LHD wiper motor removal (pics)
tomsimpson22
Post Tue Feb 06, 2007 2:40 pm
Hi all
If someone could help me with this I would be very grateful.....
For absolutely ages now I have been trying like hell to get this old (knackered) wiper motor out of my LHD 1985 325ie and have been totally unable to do so.
It is set up completely differently to the way a RHD wiper motor is set up and is apparently one large assembly instead of bolted-together sections as in a RHD.....
As the pictures show, I have removed the access panel inside the engine, and I have undone all the bolts that I can see/reach inside the wiper motor compartment, and the assembly itself seems to be totaly loose (I am able to move it around inside the compartment by reaching inside it) but it just will not come out......
There are two large black plastic objects bang in the middle of the compartment which appear to be blocking me from removing the motor...In the middle of these two plastic boxes it looks like there is some kind of motor or something (I don't think this is the actual wiper motor though).
If anybody has any experience with LHD E30's and can help me with this I would be very grateful as I'm just about at my wits end !
Many thanks to anyone who replies
Tom
edf
Post Tue Feb 06, 2007 3:27 pm
Hi Tom,
I had to do the same on my LHD because the outside wiper arm ball joint wore down and popped out. Best thing is that they are different lengths to the RHD arms, so me in the UK, before I drove to Spain, had to get a long RHD wiper arm from a scrappers and cut it in half, then drill holes in the two parts and bolt them together. Most annoying, but it managed to hold until I got here and found the time to whip one out from a LHD in the local scrappers. The black plastic things in the bottom picture I believe are the heater ducts, and the motor thing in the middle is I think the heater motor. If you remove the heater motor, and all the black plastic, you will find it a little easier to remove, but it is still very, very, very awkward. Also try not to damage the heater things lwhen you are taking them out like I did, or they might not work properly again (like mine now don't)! I was at it for ages, grazed the old knuckles, screamed at my bird, all the usual sh1t that goes on when something is not going ones way!
You do have to remove everything you can from the area to make it easiest. You might think it's a lot of work, but it's easier than working with no space, and you can also try moving the wiper arm linkage to different positions (it was nearly two years ago I was doing it, but I believe making the linkage long and thin [so it poked into the corner] was the way to do it, or was it the opposite and it was impossible like this? I'm not sure) it can make it easier, but there is nothing else I could say to do than that without coming and having a go myself, it's a case of trial and error, and twisting and working it out. If it's any reassurance, it does come out! If you are putting another in, then as you finally get it out, remember exactly how you did it, as getting it back in was my biggest problem! I believe I also ended up cutting some of the black plastic covering the motor itself, but I'm not sure I actually needed to.
Out of interest, are you breaking it or fixing it (I will be taking mine for it's first MOT in two year in March) and am expecting problems and if you are breaking it, you will possibly have parts I need! Also, where are you?
Ed
tomsimpson22
Post Tue Feb 06, 2007 3:52 pm
Hi Ed
Thanks for the reply mate :D
I am pretty much in the same position as you by the sounds of it....I'll be taking it for it's first MOT in about 2 years as well....I've had it pre-MOT'd already and it needs a couple of things doing (it's got a dodgy wiper motor, leaky shocker, water pump is knackered, it needs a fuel cap and apparently the brake pipes need renewing as well...I've got the new shocker, water pump and fuel cap but waiting on a LHD wiper assembly to come from the US).
I've been without a car of any kind since the head gasket blew on my Nissan 100NX back at the beginning of December so am quite desperate to get this one fixed and back on the road !
Also, I live in Middlesbrough......
I noticed that you said you cut some plastic from around the motor itself, as did I ! It looked like that was what was blocking it from coming out and I couldn't reach the bolts to undo any of it and ended up cutting that plastic shroud off with a Stanley knife :cry:
edf
Post Tue Feb 06, 2007 8:09 pm
Yes, that shroud is what I cut, just a slit down it! I've been looking for the under dash bit of cardboard for an LHD, and I can't find one anywhere, all the ones in the scrappers out here are knackered!
I had a brake line go on my Mondeo at Christmas (which I use when in the UK), so I got both back brake lines, from front to back done, overnight, on the 23rd December for £80 which I thought was OK. Not as cheap as a DIY, but finding the brake line, and a flaring tool, and the ends at 3.30pm on the 23rd when I needed to do 400 miles on Christmas eve was near on impossible. Watch out for the garages though, b4st4rds they are, ring and get quotes before you go down!
Surprised you didn't have a go at the headgasket on the NX, it would only have been a nifty at most and an afternoon wouldn't it, or are they difficult/expensive parts?
