wing mirrors - reverse polarity
NigelA
Post Tue Feb 06, 2007 10:54 am
Have fitted heated wing mirrors. All the connections appear correct (i.e on back of motor unit but for some weird reason the polarity has become reversed. i.e the toggle switches work the reverse way, for both mirrors, yet the connection block which attaches to the switch in the door can only go on one way. Please can anyone explain this, and therefore what the solution is.
Many thanks in advance.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
E30Mark
Post Tue Feb 06, 2007 11:10 am
Might be worth pushing the mirrors around manually, sometimes the motors get out of step with where they are supposed to be...
PM for details
NigelA
Post Tue Feb 06, 2007 11:28 am
Thanks, Mark.
Might be interested in some parts from your breaking tourer. Particularly the driver's door card (will pay for the pair anyway). Centre console (presumably in black) the reversing light switch (if you can get to it easily) and fuze box cover (if in good condition and lugs and 'clip' are OK).
Regards
Nigel
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
Post Tue Feb 06, 2007 6:08 pm
You have put the motors in the wrong mirrors :)
I did this myself unknowingly when I painted mine :roll:
stuartgallafant
Post Tue Feb 06, 2007 8:51 pm
DanThe wrote:You have put the motors in the wrong mirrors :)
:lol:
sorry dan, had to do that!!
Post Tue Feb 06, 2007 8:57 pm
Swap the blue and black wires on the back of the motor unit.
Heated mirrors should be between black and brown.
Post Tue Feb 06, 2007 10:22 pm
:lol:
No problem mate, laugh away,,,,,,,,,,, :o:
NigelA
Post Thu Feb 08, 2007 9:43 am
Many thanks, Brian. That worked but am not sure the heated mirrors are working properly even though the voltage tested there was 10.7v. Should they actually feel warm (or warmish) after a short while? And is there a cut-out or are they on all the time please?
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
E30Mark
Post Thu Feb 08, 2007 9:53 am
The mirrors are on all the time (with the ignition), test the resistance across the mirror elements, although thinking about it, you might need a low ohm reading meter? Haven't got one here to try, but i'm sure Brian will correct me, he usually does :D
PM for details
NigelA
Post Thu Feb 08, 2007 10:14 am
Many thanks, Mark. I will await Brian's comments as well.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
Post Thu Feb 08, 2007 8:26 pm
Mirrors are on all the time with ignition as Mark says.
An ordinary test meter will do to check them, even if it can't resolve enough to give an accurate reading on the resistance ranges.
Tested a few a while back, and think I concluded there were two types (probably different makes) with different cold resistances. Something like 20 ohms and 60 ohms if my memory's right. (Quite unlikely, these days!)
They should get noticeably warm to touch after they've been on a while.
Alternative (better) way to check them is to connect them to a 12V power supply and measure the current they take.
NigelA
Post Fri Feb 09, 2007 9:05 am
Many thanks, Brian. Greatly appreciated.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
E30Mark
Post Fri Feb 09, 2007 9:34 am
Blimey, i didn't realise they pulled that much current... so you reckon they take between 1.5 to 5 Amps, that must be per mirror... i assumed they were just a few watts each, hence why i thought you might need a low ohm meter.
PM for details
Post Fri Feb 09, 2007 9:39 am
Think you need to revise your "ohms law", Mark!
NigelA
Post Fri Feb 09, 2007 9:48 am
Brian. Is that three tourers you have in your pic?
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
mrLEE30
Post Fri Feb 09, 2007 11:33 am
just another thought.. are they mirrors for an E30 or something else? i only ask cause i put a switch out of a scrap E32 barge and they worked in reverse, so i assume the motors will work in reverse too... you could have the mirror innards from an E32!!
and Mark V=IR mate, low R means high I!!!
E30Mark
Post Fri Feb 09, 2007 11:42 am
:o: would you believe me if I said I was a qualified electrician, worrying really!
In my defence your honour, I'm pumped full of drugs at the moment, did my back in on Tuesday. I barely know what day of the week it is...
I'll go do some revision....
PM for details
NigelA
Post Fri Feb 09, 2007 1:19 pm
These are E30 mirror sets. They were bought with E30 cowlings and the guts changed over to the grey tourer.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
Post Fri Feb 09, 2007 9:02 pm
NigelA wrote:Brian. Is that three tourers you have in your pic?
Three of the fleet - red one's my wife's LPG powered 250,000+ mile 325, green one's the next candidate for a M50 conversion - the one that stood full of water for two years.
Four more tourings in a shed the other side of the buildings, including my M50 one.
NigelA
Post Fri Feb 09, 2007 10:13 pm
Very interesting indeed, Brian. My telephone number is 01823 326479 if you care to call me.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
sam325is
Post Sun Feb 11, 2007 8:12 pm
i have just fitted my mirors back on today and i have a similar problem. when i pust the stick up the mirror moves right, down moves left ,left moves up and down moves right :mad:
any ideas what the prob could be?
NigelA
Post Sun Feb 11, 2007 8:41 pm
Brian's idea about changing the contacts around on the back of the motor unit worked.
Brian. Checked the resistance across one of the mirrors and it was 1.67ohms! So something is wrong there it seems to me.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
sam325is
Post Sun Feb 11, 2007 8:45 pm
so i need to change the blue wire and the black wire that go into the back of the motor over?
i have just rigged up some headed mirrors too. they are connected to the black and brown wires
NigelA
Post Sun Feb 11, 2007 9:13 pm
Yes, Sam, as Brian says, switch the blue and the black over. By headed did you mean heated?
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
sam325is
Post Sun Feb 11, 2007 9:44 pm
yea lol heated. were your mirrors doing the same as mine nigel?
NigelA
Post Wed Feb 28, 2007 8:29 am
Brian. Did a resistance test and it showed 1.67ohms!. So something wrong here, is it not. But surely you are not likely to get an element go on an enclosed and sealed unit like that, let alone two of them. Hmm.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
Post Wed Feb 28, 2007 8:54 am
The only way to test them properly is to connect them up to 12 volts and measure the current they take. You may find that their resistance increases rapidly as they heat up and the current drops off.
a while ago I removed the glass from all the "stock" mirrors I have to see which were supposed to be heated and which ones were in working order.
When I had finished, I put all the working heated glass in a box and put them somewhere safe. Tried to find this box when this thread first started, but of course, I couldn't!!
From what I remember, there are at least two different makes of heated glass in use, with wildly different cold resistances. Possibly one sort is designed to have a low initial resistance to give a quick warm up from cold.
NigelA
Post Wed Feb 28, 2007 9:13 am
Very helpful (as ususal) Brian. Many thanks indeed. Will try your suggestion.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
