rite wats happend is my tourer has decide 2 stop runnin the nite it happend my mate changed a fuse and it started then cut off again he repeated this again and the exact same thing happend iv looked at a couple of threads on here and think it might b the relay or the pump so i called the dealers as u do and the guy said hes not sure which relay is in my car how can i find this out wat i got the chassis number would that help them ??
ur help would be very most appreciated
which relay
Templ8e30
I assume you mean the fuel pump relay ?
If so and it's a 6 cylinder it should be under a plastic cover next to the airflow meter, it's a blue or orange relay (deffo not the white one).
If it's a 4 pot it should be under the black plastic cover above the rocker cover.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
kempo_perth
ye sorry it is the fuel pump relay and it in the 4pot jst need it runnin so the now till i can get the 2.5 in it thanks m8 much appreciated
kempo_perth
ok removed the black plastic cover on the bulk head and found 3 relays from drivers to passenger side it goea white , blue , yellow does that mean its the blue one sorry 2 keep pesterin uz with this
Templ8e30
It's definately not the white one, that's for the ecu.
Cheers,
Iain T
Cheers,
Iain T
- Brianmoooore
It's the one that has a green/purple wire connected to it.
kempo_perth
ok guys iv been out n checked and the blue one has a green/purple wire connected so il try it n hope thats wats wrong
cheers 2 all
cheers 2 all
