Sticky Wipers
pgtips
Hi, thank you for all your advice on my last query regarding the annoying tapping from my heater matrix box. The problem is now resolved (it was the pipes going from the engine through to the bulkhead were round the wrong way). Onto my next query (320's really aren't this bad - although my wife doesn't agree), when i select intermittant on the stick, the wipers will travel a quarter into their cycle and then stop. They will judder the rest of the cycle. Also the same procedure will happen on light and agressive windscreen cleaning. Any ideas/advice as to how to get this fixed.
from PGTips in Bristol
odbod
some good advice on http://www.esatclear.ie/~bpurcell/318is ... html#wmisf
Although mione cleared up with more use and time. Prevoius owner hadn't used the car in the wet for 4 yrs!
smithy318i
