Sinking clutch pedal
braincat
I've noticed that if I rest my foot on the clutch it starts gently moving towards the bulkhead, then when I push it all the way in and release it, it goes back to standard operation. Resevoir hasn't lost any fluid and there doesn't seem to be any leaks, so is it more likely to be the slave or master cylinder going to the beemer in the sky?
gcorky
- Boost Junkie
gareth
as / when you do it, check under the carpet for fluid. it is a good paint stripper and will eat the floor unless you clean it all up. if it's bad and the car has a lot of life left, i'd pull the carpet out and replace it or jet wash it. carpets do look lovely after a blast out and the gunge that comes out is generally mingin!!!!
gcorky
- Boost Junkie
