Blocked off hose
hairydave
Post Mon Feb 05, 2007 6:44 pm
Hi, while changing the thermostat on my 325 I found that the hose that connects to the under side of the thermostat housing and the throttle body heater plate has been blocked off.
It has been blocked off with what looks like a part of the thermostat housing(?) that the hose would normally attach to.
It has gotten dark so i cant investigate further, but what i find strange is that i have not noticed a coolant level problem since owning the car. Do you think it possible that the hole in the underside of the housing has been blocked off and if so will this cause any problems?
Any advice on this problem will be much appreciated.
Thanks, Dave
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Feb 05, 2007 6:47 pm
sounds like the pipe that feeds the warm in take to the TB to give a cold charge
stick up some pic's
wildeian
Post Mon Feb 05, 2007 6:54 pm
My old sport had these blocked off, some kind of silicon in the pipe you're talking about.
My 'big 6 conversion' has them joined together.
No problems to note.
hairydave
Post Mon Feb 05, 2007 6:55 pm
Yeah thats the pipe, car is outside on the street, will post pics if that will help tomorrow when its light.
hairydave
Post Mon Feb 05, 2007 6:58 pm
wildeian, thanks very much, i will join it with something.
wildeian
Post Mon Feb 05, 2007 7:01 pm
On mine the two pipes entering the TB are joined together with a copper pipe (with coolant flowing through, not blocked)
Someone (Ant I think) commented on this mod a little while ago, and said it improves performance iirc!
