Hopefully these are easy questions........
I have blue injectors in my sport at the minute (Bosch 0.280.150.715 versions)
I was chatting to someone (probably Nelly) about getting my injectors cleaned when he mentioned that you could fit uprated M30 injectors.
My questions are....
whats the m30 injector number please?
Whats the benefit (on paper anyway) of going down the m30 injector route?
Whats the drawback of it?
Does anyone have some they want to sell?
How much are they?
Thank you one and all!
Fuel Injector Questions
SCOTT325SE
Ant
- Retired Team Member
M30's will flow more, 149.5 cc/min for the 715's, 185 odd for the M30 units, have the specs somewhere.
In short DO NOT DO THIS MOD !!
all the extra flow will do is drown the engine in un-needed fuel, the exception is any car with a Standalone ECU, or with a closed loop 02 setup like the Cat equipped cars, then the ECU can "see" the excess fuel and reduce the inj duty cycle accordingly.
M20 injectors for an M20 Scott, M50 ones are a non-starter too dude.
HTH
HTH
Email FTW
SCOTT325SE
Ant, I couldnt have hoped for anyone else to answer this thread first! You know I regard you as my font for all things engine related that I dont know myself.
I've seen the 715's listed at 155cc/min and didnt know what the M30 units were rated at. My thinkign was that if the ECU could "see" how much fuel it was getting, then it would induce less strain on the injectors or reduce the D.C. of the injector, giving a sharper burn or marginally better economy. It makes sense that the early ECU cant see it though, as it has no Lambda sensor. This was another of my thoughts.
The M50 injectors werent even on my list, so dont worry dude.
Any idea how much new injectors are (apart from 'f-king expensive') per unit? Sonic cleaning is about £25 per injector. Add new o-rings and spray feet and it probably wont be shy of £35 per unit.
Your thoughts Sir?
Your thoughts Sir?
gcorky
- Boost Junkie
SCOTT325SE
feels like thats my cheapest option.
Turbo-Brown
- Boost Junkie
Not sure that even a Lambda equipped E30 would be able to sort out the overfueling as it'll only have a certain percentage of the mapped fueling to play with, and at anything above a light load the ECU should be ignoring the Lambda sensor anyway and just running off mapped values which would mean veeeeery rich if the larger injectors were fitted.
surj
if i were you mate id go to the breakers and price up a set of injecter off say a newer 2.5 bm rather than have yours cleaned they will be newer injectors and wont over fuel but should be a lot better than those blue bosch they do the job just about but if youre after that bit more a cheap mod
gcorky
- Boost Junkie
surj wrote:if i were you mate id go to the breakers and price up a set of injecter off say a newer 2.5 bm rather than have yours cleaned they will be newer injectors and wont over fuel but should be a lot better than those blue bosch they do the job just about but if youre after that bit more a cheap mod
need the specific injector number type .......Scott save yourself a lot of trouble...clean em
theres different fuel pressure injectors,different impedance throughout the bmw range....they may appear the same...thats as far as it goes
i seem to remeber you may be rebuilding/overhauling a sport,if this is the case i assume your cleaning them as a matter of course-but if for some reason you need replacements ,ive got some you can have 90k usage..
