Aftermarket ECU sensor trigger mounting
Turbo-Brown
Boost Junkie
Post Mon Apr 04, 2005 8:59 pm
Well, I've finished off rebuilding the bottom end of my engine and should be picking up the head tomoz so I can put that together so I've been milling about doing the little things that need doing.
One of these is to fit the trigger wheel I've got for the Emerald ECU.
I had hoped that the flywheel might have something of use on it, but by the looks of it, the original ECU was updated once a month by a single plip sticking out the side of it :(
Can anyone tell me / post any pics of where they've mounted theirs.
The most practical option at the moment looks like drilling and tapping the meaty bit of the front pulley and sticking it to that, but the problem with this is that it'll mean taking the CPS off every time the fanbelt needs changing.
Cheers!
Ant
Retired Team Member
Retired Team Member
Post Mon Apr 04, 2005 9:05 pm
you can use the stock front referance sensor and pulley off any post 88 motronic M20 to run the emerald dude, I take it yours has twin pulse gens on the fly then alex ??
if so, swop the later front timing cover accross, use the matching pulse gen and pulley and thats sorted.
Unless I missing something in the translation ??
Turbo-Brown
Boost Junkie
Post Mon Apr 04, 2005 9:57 pm
Aah right, that's handy!
Better get into the wanted section then me thinks!
Did wonder why there were two sensors in the old gearbox but no holes in my new one!
Many thanks for that, exactly what I was after :)
Andy335Touring
Post Mon Apr 04, 2005 11:55 pm
My Emerald uses the stock CPS and trigger disc on my old M30,touth pattern is 60 minus 2 i think
Turbo-Brown
Boost Junkie
Post Tue Apr 05, 2005 8:20 am
Mmmm, unfortunately my car seems to pre-date all that kind of thing :(
Still, I'll get there in the end :)
Should be picking the head up tonignt! :D
