As title says tensioner spring dropped out when changing water pump
is this ok - i mean its not used once the tensioner is locked in place and because i havent moved the tensioner then i dont need the sprig right? i sippose i could squeeze it back in between the tensioner and new water pump but its not really going to do anything is it?
thanks.
help- tensioner spring dropped out when changing water pump
stuartgallafant
It won't cause a problem until the next cambelt change.
