Arrghhh
Theres alreadya control module on top of my ecu is this normal and i cna just switch this with the OBC one or do i need it and cant have a obc??
Neil
Control Module ontop of ECU OBC??
cliffybabe
- Powered by Nelly
cliffybabe
- Powered by Nelly
could it be for the standard bm alarm??
carlos_320i
Not to sure mate I have found that to day
thinking that is what is causing my OBC not to work but I have been told it is the module for the OBC
cliffybabe
- Powered by Nelly
the one in there is black but the new obc one is greencarlos_320i wrote:Not to sure mate I have found that to daythinking that is what is causing my OBC not to work but I have been told it is the module for the OBC
orangecurry
flippin' heck Neil this one was done to death last week!!!!!!!!!!
The box that weighs nothing is ONLY used for immobillising the car, via the fuel pump I believe. Are you going to use the CODE function of the OBC?
Leave the original one connected as it was in the car; all the OBC brain is in the OBC itself.
I believe all cabs have an empty box (OK it has two relays) because a cab already has an immobiliser function with that mad magnetic key (fits in the door just under the normal door lock...
Clear?
Clear?
stuartgallafant
