alternator 325i
noney82
Post Sat Feb 03, 2007 11:15 pm
think shes getting tired now battery light keeps coming on every now and again, so my question is shall i just get a normal 2.5 one or is there a better one to get that fits the same but gives better performance if you like? cheers all
kam-325i
Post Sat Feb 03, 2007 11:37 pm
Do you need the better performance ?
No need to waste money on a larger output alternator if your not going to be using it....
I would just get a normal one....
Post Sat Feb 03, 2007 11:42 pm
Better performance??? In what way?
Unscrew the regulator pack from the back of the alternator, and see if there are any brushes left.
noney82
Post Sat Feb 03, 2007 11:45 pm
Brianmoooore wrote:Better performance??? In what way?
dont know just like better all round power not bhp power mean to like electronics, i'll look at the bushes so whats there, just one of them things im not going to keep putting off
kam-325i
Post Sat Feb 03, 2007 11:52 pm
Have you got a huge ICE install ?
noney82
Post Sun Feb 04, 2007 12:00 am
no mate, just radio and a small 300w sub
kam-325i
Post Sun Feb 04, 2007 12:09 am
just get a normal one then, ive got a small ICE install with about 5-600Watt amp and it runs fine.....
noney82
Post Sun Feb 04, 2007 12:36 pm
ok cheers guys i'll get same
eltel
Post Sun Feb 04, 2007 1:16 pm
defo check the reg pack on the back...the duff brushes in mine caused your prob and they only cost £15 for new ones!!!
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
noney82
Post Sun Feb 04, 2007 1:17 pm
ok will look cheers what holds them in? screws?
eltel
Post Sun Feb 04, 2007 4:46 pm
phillips screws if i remember correctly, should see 2 metallic rods the same size and shape if all ok
noney82
Post Sun Feb 04, 2007 4:53 pm
got them out, these ok?Image
noney82
Post Sun Feb 04, 2007 4:54 pm
noney82
Post Sun Feb 04, 2007 4:55 pm
dont know why the pic so small
noney82
Post Sun Feb 04, 2007 5:14 pm
the slip rings dont look to worn either
noney82
Post Sun Feb 04, 2007 5:48 pm
just put it all back together, batt reads 11.89v, batt when car running reads 10.58, turn head lights on and the cd player stops, im guessing the alternator has had it
Post Sun Feb 04, 2007 6:07 pm
Alternator or its connections are dud.
Put the regulator pack back (stretch the brushes out a little first) and measure voltage between a cleaned up part of the alternator casing and battery negative. Should be zero volts.
If that's OK, then the regulator pack is probably all you need.
Yours looks different than what I was expecting though.
m-dtech
Unapproved Trader caution
Post Sun Feb 04, 2007 6:16 pm
IIRC the altenator from an e28 is same bolt configuration and higher output.... ??
ask 320touring what altenator he has i sold it to him and i think its from a 535i.... or 528i
noney82
Post Sun Feb 04, 2007 6:27 pm
when you say stretch out you mean pull them out so it stretches spring? when you say regulator pack you mean busshes, thing pictured above
noney82
Post Sun Feb 04, 2007 6:31 pm
bet your going to tell me the alternator is different too lol :D
Post Sun Feb 04, 2007 6:40 pm
noney82 wrote:when you say stretch out you mean pull them out so it stretches spring? when you say regulator pack you mean busshes, thing pictured above
The whole thing in your pic is the regulator pack, brushes are the rectangular carbon things sticking out.
TBH, your brushes look OK, but in the case of worn out ones, the copper braid that stops them falling out (and ultimately stops them reaching the commutator) can be pulled so that the brushes come out half a milimetre further. This will give them another 1000 miles of life.
Quick roadside emergency fix (that the RAC aren't apparently aware of, but that's another story).
noney82
Post Sun Feb 04, 2007 6:55 pm
when you say to do that test im guessing thats with the car running?
Post Sun Feb 04, 2007 7:01 pm
noney82 wrote:when you say to do that test im guessing thats with the car running?
Engine running.
I saw a £120 battery and £150 alternator changed on a vehicle once because of this. I turned up just as they finished the alternator change and were wondering why it still wasn't working! They'd managed to drop the original battery and crack it as well.
Took all of a minute to diagnose, and another minute for a temporary cure (unscrew and tighten a bolt).
noney82
Post Sun Feb 04, 2007 7:13 pm
just tried to pull them a bit they are at the end they wont pull out any
noney82
Post Sun Feb 04, 2007 7:42 pm
also my battery is in the boot so done it to engine lift point 0.01 volts showing, battery light still on tho
Post Sun Feb 04, 2007 8:17 pm
You're not including the engine to body strap in the test there, but if it starts, then that must be OK.
time for a fresh alternator, or at least a regulator pack, if you can 'acquire' one.
noney82
Post Sun Feb 04, 2007 8:58 pm
no just did it from the alternator to the front hoist point, so its the alternator gone
noney82
Post Sun Feb 04, 2007 10:29 pm
ITS JUST DIED!!!! me and the missus had to push her about 900 yards up bit of a bloody hill to. im f**ked now that cold air in ya lungs doesnt help
