my drivers side electric window has stopped working. checked to see if it was the switch itself but it appears not. I am assuming it cant be the fuse because all the other windows are working.
Just thought Id see if anyone know's what else it could be before I start taking off the door panels. Is it the motor?
Cheers in advance,
J
electric window stop working...
- Brianmoooore
Never seen a dud OE window motor yet, but there's always a first time! Dealer fit window motors are another thing all together.
Switch is the usual problem, but if you're sure that's OK, then check out the pins in the door hinge pillar plug and socket.
