hi ppl,
ive just noticed an oil leak under my car and after inspection there are about 4 splits in my steering gaitor.
i obviously need to replace this now and i was wondering what do i need to do to replace this?
and this might be a coincidence but.... i recently topped my power asisted steering bottle up with Halfords ATF oil, i did read in the manual that you are supposed to use manufacturer approved ATF oil. Is this just a coincidence or has the Halfords ATF oil weakend the rubber gaitor?
Lee
Rubber Gaitor :(
ian332isport
Hi Lee,
I'm afraid this is more than just replacing the rubber gaiters. You should not have any fluid in these gaiters at all. Your problem is leaky seals inside the rack itself. Your only option is to replace the rack. Try and find a good used one, or get a refurbished one.
Any ATF should be okay, so I doubt the Halfords stuff has caused this.
Ian.
Ian.
E30_320i
ow dear
i am about a week away from getting rid of the car and now all the problems are occuring! after the car being in the family for 15 years everything seems to want replacing now.
Lee
Lee
