help
staffy
i bought the GUG on sun an she went bang on mon great job
anyhow she went off a cylinder then blew out white smoke and blew off a hose she has mixed the water an oil might this just be a head gasket r will it be worse also wot head gasket do i get if she has a les stannard 2.7 bottom end and griffin motorsport head sorry but its my first e30 and i got 1 days ownership so no nothing
there is a flashing light that says check on the dash wot is it as i dont have an owners manual thanks
E30Mark
You need to get the head pressure tested first... no idea about the gasket needed...
The check light is normal, it's there to prompt you to check the brakes before you move off... ie press the brake pedal, if all is OK then the light will go out.
PM for details
PM for details
