dogleg box ratios/strength/etc
edf
Post Wed Jan 31, 2007 7:12 pm
Hi,
I don't know if anyone knows the answers to these questions, but I have a 3.64 lsd, a 325 engine and I presume I have a 320 box (I don't know if it's the same as a 325 anyway?) as the car used to be a 320, and I'm happy with the ratio's for cruising and also around town.
The 4.10 dif I used to have on meant I was revving 3.5k rpm at 60mph, which was crap for cruising long distances, even though it did move pretty quick off the mark.
I'm thinking about a dogleg box, but would this undo all my efforts to achieve lower revs at high speed (I've read the ratios are different)? I am also presuming that a dog leg, with some sort of "link" to racing might be stronger than a standard box, and what doglegs, on what vehicles will even fit my car?
Finally, is there a different option I should be considering as a few others in other forum posts have said that the 323 dogleg is weak, so are they all?
Post Wed Jan 31, 2007 7:38 pm
the only car i know with a dogleg box is a stripped 325i track car and it's fine
if you get the box you need a different final drive so a 3.25 diff off an M3 is what you need. The ratios on the dogleg are totally different to your box and if you kept the diff it would be soooooo slow.
a normal or sportbox off a 325i would be best. A sport box has the exact same ratios as your current 320 box by the way! So it could be one?
edf
Post Thu Feb 01, 2007 8:59 am
Thanks, I think I'll get a normal box then.
Am I right to assume all ratios are the same in the the sport/325/320 boxes? If so are they all exactly the same box or is there another difference?
Also, just to make sure, there won't be a difference between the box required for my left hand drive LHD convertible and and any RHD sport/325/320 box will there?
Ed
Post Thu Feb 01, 2007 6:20 pm
i'm not sure on the LHD drive thing but i'm expect it's no problem
right a sportbox is for a 325i, a 320 box will after time sh!t itself as it can't handle the extra power it's just coincidence the ratios are the same
normal 325i box has slightly different ratios for 1st,2nd and 3rd. 4th and 5th gear are the same on both boxes. (sport and normal 2.5)
So i would only use a 2.5 box of some kind if it was me
