Post
Mon Apr 04, 2005 9:55 pm
When mine was working intermittantly, it turned out to be a dry joint in the speedo head.
It took about an hour to re-flow the solder on all of the joints.
Also, I seem to recall that one of the connectors inside the head was a bit loose.
Finally, I kinda shimmed up the speedo unit within the head to stop it moving back and forth as the speedo seemed to work if I slammed on the brakes, but stop when I accelerated hard.
For most people though, it seems to be the wiring at the back.
325i Twin Turbo (until 10am 01/12/07
www.air-in.co.uk free M20
exhaust and inlet flange
