electric window and sunroof problem m3
tobias
Tue Jan 30, 2007 9:27 am
hi guys all of a sudden both have stopped working not sure why.....and yes i have checked the fuse its fine
thanks in advance toby
tobias
Tue Jan 30, 2007 4:50 pm
any ideas fellas???
tobias
Tue Jan 30, 2007 6:26 pm
is there some sort of relay which controls them al which may have gone?????
sorry im crap with electics lol
MONSPORT42
Wed Jan 31, 2007 12:42 am
Do they work with a door open, i.e. is it just the switches. If they are working with the doors open then it's likely to be an earthing problem. Happened for a while on my Sport especially in the wet. A member suggested cleaning/tightening the cables on the starter motor connection (disconnect battery first). They've worked perfectly ever since. Might help.
YOUR LEFT FOOT'S FOR BRAKING
eko
Old timer
Wed Jan 31, 2007 12:53 am
You are aware that there are 2 seperate fuses for the windows?
One for doors closed,one for doors open!
jpboost
Wed Jan 31, 2007 8:42 am
there are 2 relays that control the electric windows.
they use 1 relay in normal use (ignition on) , and the other one when the doors are open & ignition is off.
so if they work when the ignition is off/door is open then you know it's the other relay.
pick a relay that you know is good (i.e. something like the horn one is easy to check) and swap em over. then you'll know for sure.
tobias
Wed Jan 31, 2007 6:09 pm
your right boys!!! they work with doors open. which relay/ fuse needs switching???
thanks again for all the help
toby
tobias
Wed Jan 31, 2007 10:44 pm
what numberfuse for ignition on
eko
Old timer
Wed Jan 31, 2007 10:49 pm
this will come in handy for you i think!
http://www.e30zone.net/modules.php?name ... 0fuses.htm
tobias
Wed Jan 31, 2007 11:03 pm
hi eko electric windows on this table..... any ideas
tobias
Wed Jan 31, 2007 11:33 pm
sorry i meant it doesnt say which one for leccy windows
Wed Jan 31, 2007 11:47 pm
Fuse 17 is for the windows/roof with the ignition on. Fuse 28 is for the windows/roof with the doors open, ignition on or off. Both 30A.
tobias
Wed Jan 31, 2007 11:50 pm
cheers brian :D
marley_uk1
Sat Feb 03, 2007 1:00 am
on my car the windows aint working but the sunroof is any ideas
Sat Feb 03, 2007 10:05 am
marley_uk1 wrote:on my car the windows aint working but the sunroof is any ideas
If they boh stopped working at the same time, then probable culprit is the cut out switch. Either acting up, or a wire fallen off the back.
This assumes the wiring is as BMW intended, and hasn't been "got at".
marley_uk1
Sat Feb 03, 2007 6:15 pm
where is the cutout switch
Gortour
Sat Feb 03, 2007 6:30 pm
Cutout switch is the one in front of the drivers window switch.
gooner1
Out humping Reindeer
Sat Feb 03, 2007 8:23 pm
Can also be on dashboard, next to hazzards.
