COULD ANYONE HELP 325i
shane21
Post Mon Jan 29, 2007 8:46 pm
bought i 325 touring and would like to what common probems thay have
dilo_attax
Post Mon Jan 29, 2007 8:48 pm
rust on the sunroof..... :mad:
shane21
Post Mon Jan 29, 2007 8:54 pm
its over all not bad but find it a bit strange that its electric everything but windows!!-this normal?-and its a charcoal grey colour,was there many of these made as all the tourers i see are either red,or white
ShineOn
Post Mon Jan 29, 2007 9:28 pm
shane21 wrote:bought i 325 touring and would like to what common probems thay have
Are you not supposed to ask this before you buy it :wink:
snoops
Major Helmet
Post Mon Jan 29, 2007 9:38 pm
:lol:
snoops
Major Helmet
Post Mon Jan 29, 2007 9:39 pm
you should to atopic search thistopic has been covered lots n lots of tyms but the worst enemy of an e30 is .....RUST
fuzzy
He who sleeps with "Gingers"
Post Mon Jan 29, 2007 9:48 pm
not sure if a 'charcoal grey' type colour is rare.i dont think ive seen one before,just the more common red,white,black,green and silvers around these parts.whats the rest of the spec? does it have leather or m-tech kit :? post some pics up winkeye
shane21
Post Mon Jan 29, 2007 10:18 pm
its got side skirts , half leather, bbs alloys and trip comuter ?????
Morat
Post Mon Jan 29, 2007 10:33 pm
rust rust and then the rest. Check the wheel arches, check round mud flaps if fitted, check behind the side skirts, check the bits that look temptingly like jacking points. The scuttle below the windscreen is a weakness on all E30s. Tourer tailgates rust below the window line but it can be sorted out if you catch it intime.
Mechanically, as long as it starts, idles and pulls well you're mostly there for the engine. Make sure the oil light goes out as soon as you start the engine, check that the temp gauge never goes above the 3/4 mark even in traffic. You should check that the engine fan works properly. The fan spins (idles) all the time the engine is running, but once the engine is hot the cluch locks in and the fan will roar depending on engine speed. If you overheat the engine you can crack/warp the cylinder head its a known weakness but avoidable. Distributor caps and rotor arms are a weakness and cause poor running (of course) but are quickly replaced.
M20s can run 250k miles without rebuilds as long as they get regular oil changes.
Look out for rotten brake lines, knackered shocks and especially knackered rear shock mounts. Hnadbrake can be weak if it hasn't been looked after. They need proper adjustment and not just tightening up the cable. Then you've got array of bushes in the suspension. They're all doable, but the ones that generally cost are the rear subframe bushes because they're a bastard to get out (or can be).
Generally, the joy of E30s is that most bits can be fixed relatively easily/cheaply apart from the dreaded rust - so keep ontop of it.
shane21
Post Tue Jan 30, 2007 8:52 am
cheers morat,ive now got 2 e30's,shame ive not got a driving licence!!!-banned till june- :(
